E61 kellaaeg ja kuupäev
Hannes
Peamine sõiduk: E91 325d
Postitus Postitas Hannes »
pidevalt on kell ja kuupäev nullis. Vahepeal ka kesk. Kütusekulu. Nagu öösel millalgi poleks voolu olnud. Aku korralik ja käivitub hästi. Kunagi oli akukastis vett, äkki sellest mingi jama...
(OO==[][]==OO)
ttsys
Re: E61 kellaaeg ja kuupäev
Postitus Postitas ttsys »
Kulunud diisel, mida käivitad pidevalt väliste abivahenditega?
Hannes
Diisel küll aga mitte kulunud. Ja nagu mainisin siis aku korralik ja käivitub ilusti
(OO==[][]==OO)
Tauri_J
Postitus Postitas Tauri_J »
iDrive errorit lööb?
ilmselt aku viga
aasta?
Hannes
2007.dets ja 520d
Erroreid ei löö.
(OO==[][]==OO)
PeeterA
Telefon: 51949859
Postitus Postitas PeeterA »
Ei tasu kohe uut akut ostma tormata:
Kood: Vali kõik
Instrument cluster: power supply switched off
Symptoms:
The time and date in the instrument cluster and in the Central Information Display are lost.
The fault code memory entry ”instrument cluster: power supply switched off” is stored in the instrument cluster.
Cause:
The fault code memory entry does not indicate a defect in the instrument cluster or in the power supply of the instrument cluster, rather only disconnection of the power supply of the instrument cluster by the KGM: reset or cut off terminal 30g-f.
Reset or cutoff of terminal 30g-f is due to a fault in the vehicle: too many wakings with terminal R Off, closed-circuit current fault, sleeping inhibited, reaching the starting capability limit.
Procedure:
If there is an impairment (e.g. time was lost; see above symptoms), the test module 'Energy diagnosis' helps in finding the cause of the problem in the vehicle energy system: run the test module.
If the vehicle had a breakdown due to a flat battery despite the reset or cutoff of terminal 30g-f, it is usually the case that the control units supplied via this terminal are not the likely cause.
Hannes
vabandan rumalust aga maakeeli siis?
(OO==[][]==OO)
ttsys
Aku ise vaevalt vealine. pigem IBS või mingi haige tarbija sekkub jne.
PeeterA
Telefon: 51949859
Diagnostika tuleks teha ja kontrollida, mispärast keremoodul toite lahti ühendab.
