Race.Fi: Product topic
Autondusega seotud teenused (tasuline reklaam)
Moderaatorid: Henri., Rain., Madis.
Race.Fi
Postitus 05.01.2018 16:18 43
Weekie: Turbosmart wastegates and dump valves -10 %
Turbosmart products just got a full update, and now's also the time to get a very decently prices top-notch wastegate or dump valve.
You likely know the Turbosmart as a brand if you're at least somewhat familiar with the tuning and performance scene. They have definitely earned their place on the market, thanks to great products which can be highly depended on.
The complete Turbosmart range was just updated up to 2018 spec, so here's a great time to put the most important - waste gates and dump valves - on the weekly offer. The shop now also has all spare parts like flanges and diaphragms listed, as well as a complete list of exchange springs for different pressures.
»» Race.fi: Turbosmart waste gates and their spare parts
»» Race.fi: Turbosmart dump valves and their spare parts
Exchange springs and spare parts:
»» Race.fi: Turbosmart waste gate springs
»» Race.fi: Turbosmart waste gate spare parts
»» Race.fi: Turbosmart dump valve springs
»» Race.fi: Turbosmart dump valve spare parts
To go with your new shiny Turbosmart, a Holset turbo is also a common choice offering great turbochargers at decent prices. They're available quick & cheap from us =)
»» Race.fi: Holset turbchargers
Have a great weekend!
Race.Fi / Willem
Race.Fi
Postitus 12.01.2018 15:09 10
Weekly offer: Black Diamond brakes -10 %
On the weekly offer, no less than quality brakes from Black Diamond @ -10 %!
Good brakes are a basis for any track car and any loved family members. Throughout the years, Black Diamond brakes have gathered a great track record among customer feedback. Whereas traditional replacement pads squeal and discs get warped before even touching the pedal, BD parts have been praised quite a lot for their good quality.
The discs are treated with a black, hard surface coating which both prevents corrosion and offers a good base for further treatment as well. The discs are available as drilled, grooved and a combi model which is both drilled and grooved.
Predator pad brake pads work great on the street and you can use them with any brand of brake discs.
A constant 10 % discount is offered on full kits (two sets of discs and pads, and a hose set), and now you get the discount for individual parts as well. For full kits, make sure to ask our sales for an even greater offer.
Without further talks, here you go with the products:
»» Race.fi: Black Diamond brake discs
»» Race.fi: Black Diamond brake pads
»» Race.fi: Black Diamond stainless steel braided brake hoses
Race.Fi / Willem
This post in our site
Race.Fi
Postitus 19.01.2018 16:14 28
Weekie: Mangaflow catalysts -10%
Lets put the Magnaflow race catalysts in our weekly offer -10% 19.1.2018 - 26.1.2018!
Magnaflow free flowing catalysts are for all serious exhaust upgrades, when you need a small but very high quality catalyst what will pass the inspection and is small enough to be installed almost any car. We keep Magnaflows always in stock and actually today we ordered 30pcs more.
This racing catalyzer will pass emission measurements easily. Recently we got a feedback from our customer: With an original cat the emissions were CO% 3,86/3,40 HC ppm 470/250 and after putting the Magnaflow in place, numbers dropped to CO% 0,00/0,01 HC ppm 19/24. You can also find everything you need to mount these, for example exhaust flanges, V-band clamps, U-bolt clamps, exhaust gaskets and wide range of different heatshields in our shop aswell.
Catalyzers and other exhaust parts in our webshop:
»» Magnaflow catalyst
»» Exhaust flanges
»» V-Band clamps
»» U-bolt clamps
»» Exhaust gaskets
»» Thermo Tec heatshields
Have a nice weekend!
-Riku
Race.Fi
Postitus 26.01.2018 16:00 15
Weekie: Mishimoto radiators & coolers -10%
Our weekly offer, the Mishimoto radiators & coolers -10%. Now is the best time to upgrade your cooling system for summer!
Radiators takes care of cooling the coolant and thereby the engine - more power, more heat. Mishimoto radiators are more thicker and with bigger water capacity than original radiators, which means there is more surface area to dissipate heat from the engine. Mishimoto radiators are bolt-on type of radiators, so there is no need to fiddle with the installation, if you don't like. For custom applications we also have an extensive size chart, so you can easly find the right radiator for your car and use.
An intercooler drops air temperature with flowing cold air through the cooler. A better intercooler like Mishimoto will ensure better cooling so it's also possible to charge more air in to the engine. Mishimoto coolers, especially black ones, have more cooling surface than original, so you can reach the best cooling power even with highest horsepowers.
Mishimoto radiators & coolers in our webshop:
»» Mishimoto radiators & coolers
-Riku
Race.Fi
Postitus 02.02.2018 14:11 59
Weekie: Widebands -15€
Lets kick our most popular widebands in our weekly offer -15€. Wideband is a great additon for any tuned engine, which need more fidelity.
Innovate, Vems and PLX now in our weekly offer -15€. These three sell high quality widebands for any engine with or without EGT sensor. A wideband is also a very cheap insurance for you engine - it informs any problems before anything bad happens.
The Vems wideband is a great and cheaper choice when you also need an EGT sensor, of course its possible get the VEMS without the EGT. Innovate is a great choice when you just want a wideband with a traditional and fine look, without any other features than mixtrue ratio. The innovate DLG-1 is the dual wideband version which supports two sensors on one gauge and is a very popular wideband in most V8 engines. Last but not least, the PLX is the state of the art kit with a modern touch screen and the ability to add extra sensors like boost and egt. Recently we also got a fresh huge batch of PLX in our stock.
These widebands in our webshop:
»» Vems widebands
»» PLX DM6 wideband
»» Innovate MTX-L wideband
»» Innovate DLG-1 dual wideband
-Riku
Race.Fi
Postitus 09.02.2018 14:23 12
Weekie: Davies Craig water pumps -10%
Lets put the Davies Craig water pumps in -10% discount for a week. Electric water pump is a great choice for any car and use.
With Davies Craig eletric water pump you can get more trust in the cooling system, its possible to use it with the original pump or use only the electric pump. There is pumps available between 15-150l/min, smallest ones are with plastic body and biggest models with more durable aluminium body.
You can get water pumps separately or set, which includes the controller. With controller its possible to adjust water flow and even a fan if needed, for example you can adjust the pump to stay on for a certain time after the engine has been switched off. Most common pumps we keep in stock and we order more even twice a week if needed.
Davies Craig water pumps in our webshop:
»» Davies Craig eletric water pumps
-Riku
Race.Fi
Postitus 16.02.2018 16:14 44
Weekie: Castrol oils -10%
Castrols high quality motor oils, there is Castrol oils almost for any engine and use. Most popular oils we keep in stock.
We just put the Castroil oils in -10% discount in our weekly offer. Castrol makes one of the most popular oils in Earth and why not - price ratiot meets for sure in Castrol oils. Most popular oils are especially Magnatec and Edge series, which we always keep in stock due to large demand in 1 and 4 liter cans. In transmission or differential we recommend Amsoil oils. You can ask an offer for transmisson oils and for oil filters with the Castrol motor oils and we can offer the -10% discount for these as well.
Castrol and Amsoil oils in our webshop:
»» Castrol ja Amsoil oils
A quality oil also needs quality hardware. Our filter selection includes hand picks for some rarer models as well.
»» K&N oil filters
»» OEM oil filters
-Riku
Race.Fi
Postitus 23.02.2018 15:43 04
Weekie: Sachs SRE clutches -10%
We just put the Sachs SRE clutches in -10% discount in our weekly offer. We keep the most popular clutch parts in our warehouse.
Sachs SRE is made by ZF-sachs's performance branch. SRE clutches are available for most European cars and they offer great torque caps combined with comfortable driveability. The most popular ones like -763, -765 and -707 we have listed as they own because they are most universal clutch parts, its possible to make the clutch from these almost for every car. With the organic clutch disc, Sachs is a very good choice for street car.
There is also model specific kits available for most car and of course its possible to check the right one with diameter or bore. With our webshop partnumber search its easy to look up prices for any Sachs SRE cluch cover, clutch disc or bearing. We keep the most popular clutch items in our stock and we order more when needed, usually even twice a week.
Sachs SRE in our webshop:
»» Sachs SRE clutches
-Riku
Race.Fi
Postitus 02.03.2018 13:55 21
Weekly offer: Free oils with Quaife differentials
For the next week, all Quaife differentials come with free differential oils from either Castrol, Red Line or Amsoil, depending on the type.
Quaife differentials now come with free differential oils on the house for the next week. The offer is valid for traditional differentials where the diff is in it's own oil. The Quaife uses non-slip oils, and we have the best oils for these units from Castrol, Red Line and Amsoil, depending on your choice and preference.
Get your differential now, and please note we also do free shipping to our neighboring countries and most of Europe.
Quaife ATB diffferentials in the webshop:
»» Quaife ATB diffferentials
-Willem
Race.Fi
Postitus 16.03.2018 16:04 16
Weekly: Black Diamond -10 %
As spring is already in full motion, now's the time to do the finishing touches and upgrades, like a proper brake job!
The Black Diamond brake parts range includes quality discs, pads and hoses which actually make a brake job nice. If needed, repair kits for calipers are also available from our sales, as doing things properly the first time is actually the only smart way ;)
All-round brake kits have a permanent 10% discount, and now the individual parts are at the weekly as well.
Go shopping here:
»» Black Diamond brake discs
»» Black Diamond brake hoses
»» Black Diamond braided brake hoses
»» All Black Diamond brake parts
And as a new feature in the shop, here you can check all the available BD brake parts for your car. Just select the make and model =)
»» Model-specific search: Black Diamond brake parts
-Willem
Race.Fi
Postitus 23.03.2018 13:19 32
Weekend offer: RVS treatments -20%
For start of this weekend, RVS products were put in big discount. RVS is now available with huge -20% discount and only in this weekend!
RVS is a proven nanotechnology that allows sliding and extremely durable triboceramic surface in parts of engines and transmissions. Engines or transmissions condition improves right away and it is also protected from future wear. The RVS treatment will last 100,000km - so the price does not end up too bad, especially when the prices have now been dropped this much.
RVS treatments can be found for all applications such as engines, transmissions and powersteering. Over the years, RVS has sell a lot and today we ordered more RVS in our stock. We keep RVS products always in our shelves and ready to ship.
RVS in our webshop:
»» RVS treatments
-Riku
Race.Fi
Postitus 29.03.2018 17:48 54
Easter offer: D2 brakes & airsusp -100€
Now its good time to buy some D2 air suspension and brakes. We just put these in -100€ discount for easter holidays.
[img]//s.race.fi/media/promo_20180329_d2_en.jpg[/img]
D2 air suspension is the right choice when elegance, comfort and adjustable height is your thing. You can change the car height while driving and thats very useful when you drive in different conditions. For example its possible to adjust the height lower after a bad road.
There is four different D2 air suspension model available: Basic, Deluxe, Gold and Superpro. All the air suspensions are nowdays also very much mot-compatible. Here in Finland you only need wheel alignment report and our D2 approval document.
»» Race: D2 air suspension kits
More braking power with D2 big brakes! Big brakes are excellent update for street or race car, it's bolt-on and is delivered with any parts what you need for installation. There is two different types available, Street and Sport, of course with different disc sizes. Biggest difference in Sport and Street is the caliper size which is a slight smaller in Street kits.
Brake discs are available in 286, 304, 330, 356, 380, 400, 421 and 444mm sizes - so there is a correct one for any use and purpose. For brake pads you can use a D2 own brake pads or Ferodo pads which we can have with very fast delivery and some Ferodo pads you can find directly from our own stock. There also handbrake available for most brake kits wherter its cable or electric one.
»» Race: D2 Big Brake kits
Have a nice easter!
-Riku
Race.Fi
Postitus 06.04.2018 15:26 02
Super offer: All Eibach products -10%
Probably one of the leading spring manufacturers, Eibach is a certain choice for lowering springs, shocks and kits. Eibach also makes wheel spacers and sway bars.
Eibach Pro-kit and Sportline lowering springs
Pro-kit and Sportline lowering springs offer superior quality and ride comfort. They are also an OE choice of many factory sports kits from Audi and BMW. Pro-Kits offer drops of around 30mm, and Sportline kits 40 to 50mm.
»» Pro-kit lowering springs
»» Sportline lowering springs
Eibach Pro-kit and Sportline B12 suspension kits
The B12 kits come with Eibach springs and Bilstein B8 dampers which offer firm damping and are designed for lower springs. Most models also have an upside-down design for increased rigidity. Most customers change cars from time to time, and this is a kit many get for their new car as well. That's about as high as customer satisfaction can get ;)
»» Eibach Pro-kit B12 suspension kits
»» Eibach Sportline B12 suspension kits
Eibach Pro-street S coilovers
Eibach Pro-street S coilovers offer a very sporty driveability and a stepless height adjustment, still maintaining a lot of comfort. Offering drops of 20 to 70mm, the Pro-Street S coilovers are a choice of a gentleman seeking the perfect stance.
»» Pro-Street S coilover kits
Eibach Anti-Roll-Kit sway bar kits
A sway bar kit is the overlooked way to increase stability in cornering without sacrificing any of the comfort. Stiffer roll bars keep the car level in corners, and at the same time allow for softer and more comfy springs - or overall better track performance of course - your choice!
»» Anti-Roll-kit roll bar kits
-Riku
Kirjoitus sivuillamme
Race.Fi
Postitus 13.04.2018 13:44 42
Weekie: Mishimoto radiators -10%
We just put the Mishimoto radiators in -10% discount in our weekly offer. The Mishimoto cooler increases cooling performance and guarantees perfect operation even in the toughest conditions.
Mishimoto radiators
Mishimoto radiator is a model specific and high quality product which will replace the old original radiator. Mishimoto is more effective than original and excellent choice for any car which needs more cooling power with a great price - no more cooling problems. Mishimoto radiators has a bigger water capacity and engine temperature stays low even in the summer on traffic lights. If there is no suitable model specific radiator available, we have attached a pdf from all Mishimoto radiators in webshop. Most popular Mishimoto models we keep in our stock.
»» Race: Mishimoto radiators
Mishimoto coolers
Mishimoto cooler makes sure that the supercharged air is cool enough and the more cooler the air is the more it can be charged to the engine. Mishimoto cooler cools better exchange and flowing intercooler significantly improve the performance of the engine. With Mishimoto cooler the flow resistance is smaller and the turbo or supercharger thong produced by the hot charge air cools more efficiently than the original cooler. You can find the Mishimoto coolers with dimensions so they will fit almost for any car. Most popular ones we keep in stock ready to ship.
»» Race: Mishimoto coolers
Race.fi / Riku
Race.Fi
Postitus 20.04.2018 12:59 04
Weekie: Race.fi products -10%
We just put some Race.fi products in our weekly offer -10%. There is discount for example in fuel pressure regulators, boost controllers and shortshifters.
We put discount directly from our stock Race.fi parts. For example the following products are available for a great price:
Boost controller BC1
Good quality and working boost controller, which allows to change boost pressure easily by rotating the adjustment. Controller can be kept in engine room, or drag it to cabin, when the adjustment will be really easy. Package includes the controller and for installation hoses and clamps.
»» Race.fi boost controller
Fuel pressure regulator FPR-1
One of the Race.fi top sellers - more than thousands of sold regulators. Fuel pressure regulator with gauge keeps the fuel pressure going to injectors in ratio with intake pressure appropriate, when the car controlling system knows to inject correct amount of fuel to engine. Works with fuel injected cars, turbocharged or non-turbo.
»» Race.fi fuel pressure regulator
Shortshifters
Short shifter makes the gear gap by 25-40% and makes it more accurate. For example switching for 3rd gear to 4th is much shorter. Installing is easy, take old one out and replace with brand new Race.fi short shifter. Stock includes short shifters for example BMW, Nissan and VAG-concern cars.
»» Race.fi short shifters
All Race.fi products in webshop:
»» Race.fi products
-Riku
Eelmine
Mine Teenused
Kes on foorumil
Kasutajad foorumit lugemas: Registreeritud kasutajaid pole
