38. leht 126-st
Re: Huvitavat laiast maailmast
Postitatud: 20.04.2011 18:03 22
Postitas Slava_323
--kala-- kirjutas:Zipp kirjutas:No Slava, link ka juurde ikka
vaata koledatest
5 pluss
Postitatud: 25.04.2011 13:25 47
Postitas Cert85
Postitatud: 26.04.2011 09:46 23
Postitas Zipp
Postitatud: 26.04.2011 10:06 12
Postitas Zipp
Postitatud: 26.04.2011 10:25 58
Postitas symmi
On veel mingit infot või foorumi linki selle kohta?
Postitatud: 26.04.2011 13:35 35
Postitas Cert85
Postitatud: 27.04.2011 16:32 58
Postitas Zipp
nos?
Postitatud: 27.04.2011 17:13 11
Postitas Penu
peaks nagu dry nos kit olema. Ei saa aru, kas siis kütuse kompenseerib mootor ise või pihustavad ka seda juurde...
Njää, pole asjatundja
lugemist: Dry Nitrous Kit
The typical dry kit is one of the most simple kits available. The kit is called "dry" because it injects only nitrous into the engine, and not fuel. Generally, the dry kit is for people who want a set that allows them to let the ECU or computer automatically add appropriate amounts of fuel to compensate for the added nitrous into the motor. Usually you can get away with a dry nitrous system if you are confident in your car or truck automatically compensating fuel, you have a larger fuel system, or have a way of ensuring there is adequate fuel when the nitrous gets injected.
Wet Nitrous Kit
The typical wet kit is only of the more popular nitrous kits amongst enthusiasts. The wet kit injects both nitrous and fuel into the engine at the same time. As with the dry kit, you still need to have enough fuel in your fuel system for the wet nitrous system to be able to use while the nitrous is being injected. You can setup an external fuel pump specifically for this kit, so when the nitrous is activated, the fuel will come with the external fuel pump, bypassing the stock fuel system. This is a more elaborate wet nitrous system, but can be one of the most reliable setups.
Article Source:
http://EzineArticles.com/2279980
Postitatud: 30.04.2011 14:25 14
Postitas Cert85
BMW Lo Rider (2009)
http://motorcycle-desktop-wallpapers.bl ... rance.html
http://www.motorcycledaily.com/2008/11/ ... mwconcept/
On ka teada, mis nendest masinatest lõpuks sai, kas jõudsid tootmisesse?
Ma kahjuks pole ise juttu läbi lugenud.
Masin(ad) mulle iseenesest väga meeldivad.
Postitatud: 05.05.2011 20:15 28
Postitas oja87
Postitatud: 05.05.2011 21:50 04
Postitas Kivissaar
**** mind huvitaks kuidas ta kere ära toestas. omal kunagi oli sarnane idee e34jaga aga kahjuks ei jõudnud niikaugele.
Postitatud: 06.05.2011 02:06 44
Postitas matu4
Postitatud: 06.05.2011 17:37 10
Postitas oli
Hong Kongist siis selline huvitav pill
Postitatud: 06.05.2011 22:13 32
Postitas Kustas
Tutvustavat juttu BMW elektriauto programmi kohta.
http://www.youtube.com/watch?v=fVlPqVx4lK4
Postitatud: 12.05.2011 23:15 10
Postitas coiff
Postitatud: 15.05.2011 01:57 44
Postitas Henri.
Postitatud: 16.05.2011 11:35 23
Postitas Zipp
Bimmerfestilt veel:
Postitatud: 16.05.2011 20:16 04
Postitas captjones1
Henri_J kirjutas:]
Postitatud: 17.05.2011 09:46 48
Postitas Madis.
Stirling Moss ei ütle sulle ilmselt mitte midagi?
Postitatud: 17.05.2011 14:47 11
Postitas oo7
Herr Moss oli võidusõitja.
Mismoodi see selle jubeda esiotsaga Z3-ega seotud on
Postitatud: 17.05.2011 15:21 14
Postitas Donald
oo7 kirjutas:Herr Moss oli võidusõitja.
Vaata Striling Mossi McLaren SLR-i
Postitatud: 17.05.2011 15:26 10
Postitas oo7
Tean mis autost jutt, lihtsalt see Z3 ei näe kaugelt ka isegi natukene sarnanegi välja
Stirling Mossi originaal võislusmasin veelvähem
Muidu tuuleklaasi idee on hea... Mingi Porche mudel on samuti madala klaasiga ja näeb päris uhke välja, lihtsalt see neerude ära kaotamine muutab selle auto koledaks
Postitatud: 20.05.2011 22:09 25
Postitas thiery
Keegi kingitust tahab?
Sihuke kingitus oli täna Viimsis:
Postitatud: 20.05.2011 22:22 24
Postitas tarvo525i
hea kink
Postitatud: 20.05.2011 22:59 26
Postitas HeavyCuda
Kellegi rikka võsuke sai endale esimese auto ???
Postitatud: 20.05.2011 23:49 34
Postitas coley
Üldiselt olen korduvalt seda siin foorumis maininud aga peab vist kordama... Teiste rahakotti ei ole vaja uurida ning mis vahet seal on kes kellele mida kingib. Pole mõtet kohe hakata sildistama "kellegi rikka võsuke".
Postitatud: 21.05.2011 00:02 21
Postitas HeavyCuda
Coley, ära seda nüüd isiklikuks tee
Ei või enam midagi naljaga poolekski öelda
Postitatud: 21.05.2011 00:16 22
Postitas Henri.
Postitatud: 21.05.2011 10:04 06
Postitas Zipp
Järjekordne X6M Tallinnas
Ja kui rajapäevalt tulles rehvid autosse ei mahu
Keegi meie foorumist ehitab?
Postitatud: 26.05.2011 21:35 51
Postitas Kustas
