Huvitavad BMW müügikuulutused
- fedja
- Peamine sõiduk: MB W447
Mis sel mootoril siis teistmoodi on võrreldes 236kw mootoriga?
- toivoku
- Peamine sõiduk: 524td
lahjem on tunduvalt ju
Üles pimbitud M52.
- fedja
Jah...toivoku kirjutas:lahjem on tunduvalt ju
Mõtlen natuke täpsemalt.
Pmtslt stroker teravamate nukkadega.
- Raghza
- Peamine sõiduk: 335i N55 DCT
fedja kirjutas:Mõtlen natuke täpsemalt.
Wikipedia kirjutas: S50B30US
USA versions of the 1994-1995 E36 M3 are powered by a 3.0L tuned version of the M50 which produces 179 kW (240 hp). This engine was based on the M50B25TU and uses the same compression ratio, but uses a different crankshaft, connecting rods, and pistons. At the 1996 facelift, this engine was replaced by the 3.2 L S52.
The S52 is a higher performance version of the M52 which used for the post-facelift (1996-1999) North American E36 M3, replacing the S50B30US.
Compared to the S50 engine used elsewhere, the S52 is less powerful and features more in common with the regular M52 engine. As per the North American M52 engine, the S52 uses an iron block, aluminium head and single VANOS. Unique to the S52 is a bore of 86.4 mm (3.4 in) and stroke of 89.6 mm (3.5 in) for a total displacement of 3,152 cc. The engine is rated at 240 hp (179 kW) at 6,000 rpm and 236 lb·ft (320 N·m) of torque at 3,800 rpm.
Other upgrades over the M52 include lighter camshafts with more lift and duration, piston rings, valve springs and the exhaust system.
Bore on ka suurem.mall0c kirjutas:Pmtslt stroker teravamate nukkadega.
- Sten.H
- Peamine sõiduk: BMW X5 3.0d E53 FL ´04
Sellel kuulutusel peaks veel Individual kiri ka olema kuna haruldane 2.9 V6 170kw diisel ka aiste vahel .
BMW 325ti E46 M 2002 (141kw/245Nm), BMW X5 3.0d E53 FL Maritime 2004 (160kw/500Nm)
- Chris_P
Telefonis keeruline kopeerida aga kes otsida viitsib, siis autorahaks poistel on makroflex edition masin müüa.
Mingi Honda oli, nüüd BMW ka või?
Seitsmene bemm e38 on neil mingi kameeleon edition,äkki on isegi siia postitatud,ei ole väga lapanud
tegin sellest pullist screenshoti isegi mõnipäev tagasi
- jaanis_!
- Peamine sõiduk: X5 E53
Kena rull http://www.auto24.ee/used/2212462" onclick="window.open(this.href);return false;
http://www.auto24.ee/used/2215145" onclick="window.open(this.href);return false;
tundmatu e34
tundmatu e34
Tehasest hõbedane ja PAREMPOOLSE rooliga. Arvele ei saa. Huvitav et kuulutsues pole mainitud.
- agentzero
- Peamine sõiduk: IS250
Pukseerimiskonks ka ilusti küljes ikka Võiks siis pildi jaoks vähemalt ära kruvida selle sealt.
- Reimers
- Peamine sõiduk: CUPRA ST400
Kirjutab ju et veepump andis saba sellest ka konks
- Peamine sõiduk: E92 325i
Muidu paarutas leedu nr-iga nüüd eesti transiidid pand.
Seda on proovitud autoplussis ka leetu ja lätti müüa. Siin vaevalt lahti saab.
- because
- Peamine sõiduk: E36 328i M-pakett
Tuttava oma, leedust toodud küll jah aga võin väita et väga hästi hoitud ja hooldatud tema poolt, kõik mis vahetust vajanud on tehtud. Eestis arvele saamisega jah võimalik et probleeme, aga suveks ikka ülimõnus pill nautimiseks.
- Reimers
Kuskohas seda siis nautida kui regada ei saa ? 12k põllurallikas või
Ringrajal.
Mis ringrajal?!
Selleks, et piima (loe: madalal lennata) saada ei ole vaja teatavasti lehma (loe: Gallardot) osta.
http://www.auto24ring.ee/est/teenused/3 ... gallardoga
- because
Ei jah, Eestis ei saa ju selle autoga ringi üldse sõita kui regatud pole..Reimers kirjutas:Kuskohas seda siis nautida kui regada ei saa ? 12k põllurallikas või
- Tauri_T
Kas sa ostad siis endale auto mida ei saa Eestis arvelegi ja sõidad sellega paar aastat ringi, kuni leiad järgmise lolli kes sõidab samuti paar aastat jne.. Mõistlik tegevus.because kirjutas:Ei jah, Eestis ei saa ju selle autoga ringi üldse sõita kui regatud pole..
Ainus variant kusagil naaberriigis arvele võtta ja seal kindlustus ka teha. Vähemalt viimati kui mina uurisin, siis Eesti kindlustused ei kindlustanud välisriigis arvel olevat sõidukit.
