E34 esivõre eemaldamine
kuidas eemaldada E34 esimese võre katet?
selle pildi peal
http://www.realoem.com/bmw/showparts.do ... g=51&fg=20
detail number 10.
selle pildi peal
detail number 10.
http://www.bmwe34.net/e34main/maintenan ... adlamp.htm
Teema on küll esitulede vahetus, kuid esivõre eemaldamine on üks selle protseduuri eeldustest.
1. Removal of the center grill is difficult. The plastic retaining clips at each side (behind the lowbeam lamps) are totally blind so you have to know in advance which hidden plastic tab to push on with a 10" long and narrow screwdriver. Cast a shop light on the back of the headlamp assembly and look down the access hole for these two locking tabs. You will not see the tabs, but you will see a set of holes cut out of successive body panels. You screwdriver passes through these. Try to center it in these holes laterally, and bias the screwdriver toward the front of the holes. If you feel it hit something slightly springy, then the tip is on the retaining tab. You have to push quite hard to get the tab to release the side wing part of the center grill. Even with the tab release, it took a lot of prying pressure to get those wings loose with a screwdriver.
Be careful not to scratch the paint. See Bentley manual for pictures.
BMW 549i/6
- Marko S
- Peamine sõiduk: E39 530d
AARE530 kirjutas:Nagu öeldud- stange maha (kuigi sõber Velts võttis mingi valemiga ka ilma stanget maha võtmata nina puhtaks) ja edasi on juba loogika küsimus, pole siin mingeid skeeme ega midag vaja
Ma sain ka esimese korraga ilma stanget maha võtmata nina puhtaks.Midagi keerulist seal küll ei ole Veidi loogilist mõtlemist ja pusimist ning käes ta ongi!
