K: kust saab 525i (M50) kelladeploki juhtmete skeemi?
sillufromIV
Postitus Postitas sillufromIV »
Teab keegi, kust saaks 1992.a 525i kelladeploki juhtmete skeemi, värvide järgi? Netis on piksliteploki vahetamise juhendeid ja muud sellist aga ma aretan kellasid eraldi vanemale masinale ja oleks tarvis juhtmete värvide järgi otstarvet teada. Takistuse järgi otsimine kuhugi ei viinud (vähemalt, kui plokk autost välja võetud sai). Või on ehk e32 750i kohta sarnast teavet kellelgi?
Kas BMW 5. seeria raamatutes, mida turul venekeelsetena müüakse, on nii peen info sees?
Tänan ette abi eest.
Silver
Suzuki GSX 750 WR; Skoda Rapid Scout, Berlingo 2001, Vivaro 06, H1 06, Jimny 99 ja Samurai 02.
iaanek
Re: K: kust saab 525i (M50) kelladeploki juhtmete skeemi?
Postitus Postitas iaanek »
yllar21
Postitus Postitas yllar21 »
Pistikud:
X16 26-pin, beež
X17 12-pin, (pruun)
X271 12-pin, hall
X502 26-pin, valge
# X16
1 Airbag
2 CCM
3 CCM LCM Comp
4 CCM
5 Charge indicator control
6 Oil pressure indicator control
7 Terminal 15 power Fuse
8 ASC
9 Oil temp (M5)
10 Ground, brake pad signal
11 Traller turn signal indicator
12 Terminal 30 power
13 Terminal 30 power
14 Not used
15 Brake fluid warning
16 SIA reset
17 Ti signal for fuel economy
18 TD signal for tachometer
19 Not used
20 ABS indicator control
21 Airbag indicator power
22 High beam indicator power
23 Data line CCM Comp
24 Temperature sensor ground
25 Brake pad warning
26 Temperature gauge signal
# X17 12pin
1 Ground
2 RxD diagnosis
3 Terminal R power
4 Cluster programming
5 Cluster programming
6 Cluster programming
7 Cluster programming
8 Cluster programming
9 Cluster programming
10 Cluster programming
11 Cluster programming
12 Cluster programming
13 Ground
14 TxD
15 Terminal R power
16 Cluster programming
17 Cluster programming
18 Cluster programming
19 Cluster programming
20 Cluster programming
21 Cluster programming
22 Cluster programming
23 Cluster programming
24 Cluster programming
# X271 12 pin Gray
1 Not used
2 Fuel level warning signal
3 Not used
4 Fuel level signal
5 Not used
6 Not used
7 Park brake indicator control
8 Vehicle speed input (+)
9 Not used
10 Vehicle speed input (-)
11 Not used
12 Not used
# X502 26pin White
1 Fog light indicator control LCM
2 Sound tone signal
3 Check engine indicator control
4 Gear range signal
5 Gear range signal
6 Gear range signal
7 Not used
8 Transmission EGS
9 Transmission EGS
10 Not used
11 Gear range signal
12 Not used
13 Not used
14 Instrument illumination power
15 Not used
16 EML
17 EML
18 Vehicle speed signal output
19 Not used
20 Not used
21 Not used
22 Not used
23 Check control reset signal Comp
24 Not used
25 Left turn indicator control
26 Right turn indicator control
Skeemimajandus
http://www.upload.ee/files/1664139/E34_ ... s.pdf.html
BMW e34 525tds 105kW & Honda CBR1000f 98kW & CBR1000rr 126kW
sillufromIV
Pistikud on kellade taga kollane ja sinine, (16- ja 18-pin kui õigesti mäletan).
