e39 touring kütuse filter
kes teab kus saab kütte filtri täpset asukohta teada.
Re: e39 touring kütuse filter
Bentsukas või diisel? Mis mootor on?
trykkal kirjutas:kes teab kus saab kütte filtri täpset asukohta teada.
Indrek
The fuel filter is under the vehicle on the left side. You have to remove a plastic cover in order to actually see it. It is easy to replace. Pinch off the rubber fuel lines in front and in back of the fuel filter, then just un-clamp the hoses from the filter. Make not of which way the arrow on the filter is pointing so you can put the new fuel filter on the same way.
![Pilt](http://z.about.com/d/autorepair/1/0/e/9/77994466.gif)
See küll 528, aga karta võib, et Sinulgi teisiti pole.
E: Ei pannudki tähele, et touring, siis pole ma kindel. Aga võid kontrollida.
