![Confused :?](./images/smilies/icon_confused.gif)
Siit küsimus, kas M-Tech vedrul on mingi eriline märgistus, mille põhjal teda eristada teistest? Või mille järgi üldse ära tunda M-Tech vedru?
Kas E36 ja E30 kerega autodel on samasugune tagavedru?
väga imelik juUM-i varuosalett ei oska ka vastata
siin ei ole ju vastust1.8 Liter and the "i" is for injected. Now there's also a model called the 318is. The "s" stands for sport because the "s" version has the oversized heads,means more HP and the "M" suspension. The "M" suspension is setup lower and stiffer than the normal BMW suspension. The main difference between the 2 models is 25 horsies and the M suspension and of course seats and the instrumentation cluster.
