Question...
For English speaking users
ReinisLV
Question...
Postitus Postitas ReinisLV »
Can anybody tell me what kind of brakes this car got?
mm in front and back... and what kind of supports?
One friend is building now e30 with s50b32 and got questions...
Thank You!
raimo_r
Postitus Postitas raimo_r »
If you really want I can ask it from the owner, but i think he uses stock brakes with Ferodo DS2500 brake pads. since it is mostly a drag car, the brakes are needed only to slow down once.
if you want better brakes to e30 then look for here
http://www.300mm.de
Watever brakes you go with i suggest at least Ferodo DS2500 pads or similar.
Silwer
Postitus Postitas Silwer »
If I remember correctly this car had the standard brakes.
www.300mm.de is suggesting 312mm brakes for E30 + S50B32. Translated by Google: http://www.google.com/translate?u=http% ... en&ie=UTF8
Original: http://www.300mm.de/new/vergleich.htm
ReinisLV
Thank You!
...i just somehow remember from summer, that he had smth other in the back :roll: or maybe I just mix smth...
