TSI: DIS GT1 - Iga bmw omaniku diagnostika
Foorumi reeglid
ttsys
Re: TSI: DIS GT1 - Iga bmw omaniku diagnostika
Mis aasta E61? Minu käest saad sellised: viewtopic.php?f=56&t=198632" onclick="window.open(this.href);return false;
- allanasi
- Peamine sõiduk: E60 530D
Tervist , kas keegi oskaks Tartus vaevatasu eest prgogrammi installida inda/ediabas
cd olemas ja õpetus samuti , aga endal jääb mingi koha pealt puudu .
Kõik peaks olema installitud õieti driverid jne .
55624041 , kui kellelgi peaks olema aega.
Äkki mõne lahendus mida ma toon all pool sobiks kellelegi ka. Mul on ostetud naebay-st mingi romania diagnsotic cable koos kogu tarkvaraga. Sain ta käima panna juhendi järgi, isegi DIS-i ka, vot sellega oli raskem, minu jaoks. Tegelikult kui lihtsalt teha nii nagu on kirjas, siis peab toimima. Isegi mees vastas sõnumitele, aga vastasuses olid samad sõnad mida ma lugesin manuaalist välja. Kui tahad et keegi seletaks sulle kuidas korda teha, siis võid ka vigu saata, peaks ju midagi olema, mis errorit näitab?
I will exaplain a few errors that might appear durring installation or after installation:
- if you have windows7 or windows vista you might see an error saying the program needs Windows NT/XP
to be installed, if you close that window you are prompted after that with another window and first
button is "Reinstall using Recommended settings", choose that one and it will install normally.
other examples for Compatibility mode: http://www.howtogeek.com/howto/10436/us ... windows-7/" onclick="window.open(this.href);return false;
- if you receive an error while trying to run Diaghead.exe it's because your windows is either 64bits which isn't supported or because .Net Framework 3.5 is missing which can be found here:
http://www.microsoft.com/en-us/download ... aspx?id=21" onclick="window.open(this.href);return false;
- if you open Inpa and both dots near Battery and Engine are OFF while the cable is connected to pc and car and Ignition is On it's because the cable wasn't installed on Com Port1 and latency
wasn't set to 1 as per instructions
- if you run DIS and you get an error 200.159 or 200.166 it's because VMware doesn't have the correct IP's set
in the Virtual Network Editor or because you didn't run IFhsrv32.exe and Diaghead.exe or if the cable isn't installed on Port Com1 and latency set to 1 or because Windows Firewall is On and/or the antivirus is On and it's blocking traffic between virtual adapters
- if you run SSS and you get a message saying "Connection is disturbed.." it's because Windows Firewall is On and/or antivirus is On
- if you run SSS and you get a message saying "Connection wasn't successfull.." check that you opened IFHsrv32.exe
and that the cable is installed on Com Port 1 and latency is set to 1
- if you try SSS and you receive this message "It is necessary to use OP(P)S/ICOM for the connected vehicle for programming/coding control units. For this purpose, you must close the Progman session and select one of the requested interfaces."
you must go into the top menu of VMware and there select VM -> Snapshot -> press here to start SSS 3 times faster - configured ICOM
if you still have issues I can remote connect to your pc using TeamViewer and help you,
Kind regards!
Kind regards!
Kas äkki leidub Saaremaal ka kedagi, kelle arvutis jookseb DIS või on võimeline selle mingi raha eest minu arvutis jooksma panema? Omal ei õnnestu kuidagi...
Tervist!
Ehk oskab keegi öelda, kust saaks INPA/EDIAPAS töökorras programmi
BMW E60 525D
Internetist? Ebayst?
INPA vähemalt, sellest teisest asjast ei tea midagi
internetist jah aga kust lehelt täpsemalt?Ma®tin kirjutas:Internetist? Ebayst?
BMW E60 525D
- darkie
- Peamine sõiduk: 750iL
Google aitab.
http://www.ebay.com/itm/Tiny-ADS-Interf ... ls&vxp=mtr" onclick="window.open(this.href);return false;
Kas see on sobilik kaabel vanemate bmw'de diagnoosimiseks?
Buumer Auto / 56826000
- PeeterA
- Telefon: 51949859
Jah, see on OK kaabel. Arvuti peab aga olema native(tehases emaplaadile integreeritud) COM-port'iga. Hiljem juurde poogitud USB-COM-port adapteritega ei hakka tööle. Op. süsteem peab olema kah 32bit.
Silver88
- Peamine sõiduk: F15 50iX ‘15/X3 F25 2.0iX 13’
- Telefon: 56642342
Kas selline Expresscard to RS-232 adapter ei töötaks vanema ADS protokolli jaoks?
http://www.ebay.com/itm/Express-Card-34 ... 4adb148ac7" onclick="window.open(this.href);return false;
see on ka ju põhimõtteliselt adapter...
- -Priit-
- Peamine sõiduk: F31 320d '14
Ei tööta jah sellise asjaga, sai ise juba kunagi proovitud, kui veel sobivat arvutit ei olnud.
BMW F31 320d '14, BMW E30 320i '84
- bmw-vanos
- Peamine sõiduk: e46 330d 150kw,6 manu
kas keegi saaremaalt ka osaks aidata selle INPA installimisega?
mingi tasu eest.
mingi tasu eest.
Silver88
- Telefon: 56642342
Kas keegi oskab öelda kas selle jullaga saab ADS protokolliga autole ligi?
http://www.ebay.com/itm/1pcs-140cm-Adap ... ls&vxp=mtr" onclick="window.open(this.href);return false;
Tundub lihtsalt olevat üleminek 16pinilt 9pinile?
ttsys
ADS see ei toeta.
- j4nx
- Peamine sõiduk: 07 Grand Cherokee Overland 3.0crd
Tere, kas keegi oskab öelda, kas selle kaabliga peaks saama kõikidele moodulitele ligi 2004 aasta e60le?
http://www.ebay.co.uk/itm/221664229625?redirect=mobile" onclick="window.open(this.href);return false;
Või hoopis selle vähe kallima kaabliga? Tundub suht sama olevat nagu eelmine.
http://www.ebay.co.uk/itm/161577999787?redirect=mobile" onclick="window.open(this.href);return false;
Kui just praak ei satu, siis mõlema kaabliga saad e60 kõikidele plokkidele ligi. Kallimal lihtsalt 2K lüliti lisaks, mis vajalik vanemate masinate puhul.
Kust saaks alla laadida DIS-V44?
Viimati muutis attention, 27.02.2015 14:36 30, muudetud 1 kord kokku.
Ei tea kas siin keegi vastab aga proovin siiski: '
Probleem 2004a. e60 kodeerimisega. Nimelt NCS annab esimesena vea, et FA $163 on vigane... ok kustutasin selle listist ära, nüüd ilmus vin koodi alla kogu auto FA list nagu peab, aga F6 (Back) nuppu vajutades (et asuda kodeerimise juurde) ilmub kiri: COAPI-1000: error.
2003a. E60 peal ncs toimib probleemideta. Olen proovinud ncs i faile vahetada /uuendada, pole kasu millegist..
Lisan siia error.LOG failist jutu:
ERROR! Modul: AT_PROC.C, ProcNr: 31, LineNr: 01, ErrorNr: 114.
Mark Not Valid: $163
ERROR! Modul: COAPI4.CPP, Proc: coapiSetAuftrag, LineNr: 03, ErrorNr: 1180
COAPI-1180: vehicle order is invalid
ERROR! Modul: CVT_PROC.C, ProcNr: 02, LineNr: 10, ErrorNr: 106.
CIC_C03_CDM_just
ERROR! Modul: COAPI.CPP, Proc: coapiGetFswPswFromAsw, LineNr: 02, ErrorNr: 1000
COAPI-1000: error
Ja selle auto FA list:
E60_#0404&ABAT%0475$205$216$229$255$320$354$430$431$435$441$488$502$508$522$524$534$540$548$563$590$609$672$694$698$785$825$884$915$928*NC71-B110
Kas oskab keegi anda nõu, mida teha...?
CIC_C03_CDM_just
COAPI-1000: error
Kust otsida viga esimese errori kohta, teise sai kustutada aga esimene jäi.
Ja kas see on seotud Webasto tööga? Hetkel webastole käivituskäsku ei anta, webastos endas ühtegi viga pole.
ttsys
AC probleemid. Võid ref sealt vaadata;
http://www.bimmerfest.com/forums/showth ... p?t=623535
Mis temp.anduri kohta see viga ikkagi on?
Ja teine viga tuleb ka tagasi mingiaeg, tegemist on 2001a 530d ja sellel kliimavendil pole ju releesid vahel?
Või mis relee kohta see viga võib olla?
ttsys
Nu DIS või ISTA/D seletaks selle juhtumi sulle paremini lahti. Lisaks WDS-st abi, kust saad skeemi vaadata.
Ei oska keegi miskit öelda selle kohta?attention kirjutas:Ei tea kas siin keegi vastab aga proovin siiski: '
CIC_C03_CDM_just
COAPI-1000: error
ttsys
Mis taust sellel moodulil? Sama auto peal koguaeg olnud? Tekib mõte, kas moodul on mõne teise auto pealt võetud ning proge ei kattu selle autoga või siis valesti progetud(?) Lahendus on näiteks vaikimisi Progman-iga lihtsalt üle lasta ja siis uuesti vaadata. Sellega saaks välistada ka mooduli siserikke.
Taust on kahjuks teadmatta... ise pole ühtegi moodulit vahetanud. Ehk seletad veidi "Progman- iga üle laskmist". Et kuidas täpsemalt käib see...ttsys kirjutas:Mis taust sellel moodulil? Sama auto peal koguaeg olnud? Tekib mõte, kas moodul on mõne teise auto pealt võetud ning proge ei kattu selle autoga või siis valesti progetud(?) Lahendus on näiteks vaikimisi Progman-iga lihtsalt üle lasta ja siis uuesti vaadata. Sellega saaks välistada ka mooduli siserikke.
saab ka ilma optilise peata kuid õnnestmise tõenäosus on jube väike ja aega kulub meeletult.
ttsys
Saab vaid seda, mis most ei puuduta. Samas vajavad mitmed moodulid nn kohaloleku kontrolli ja see käib optika kaudu. Siis on ikkagi puuks ja viga kirjutatakse sisse. Ainult ühe kaupa saab emulaatoriga ligi ja väga vähestele moodulitele.
