3. leht 48-st
Postitatud: 07.03.2007 19:13 23
Postitas tanele28
Postitatud: 07.03.2007 23:33 42
Postitas Kustas
Postitatud: 08.03.2007 19:08 02
Postitas Roland325
Päris hea video
Postitatud: 11.03.2007 22:59 03
Postitas Roland325
Äkki see - Krt ei tea, mis jõud seal peab olema, seieri järgi kuskil 180 juurest võttis veel ratta ringi :shock:
Postitatud: 11.04.2007 12:44 03
Postitas Silwer
Tuunitud 318is:
Postitatud: 11.04.2007 17:27 58
Postitas Silwer
Mootoriks on vast ikkagi S42 mis vahetas välja S14 mootori. Ehk siis Motorsport aretis M42 (318is) baasil. See oli siis see 2,0 mootor millega võisteldi E36 kerega.
Pilt kah:
"The S42 engine was a 2.0L touring car engine with a 86.5mm bore and around a 85mm stroke, which shared the same block as the street going M42. Unlike the common M42, the S42 had a more sophisticated engine management system, and had individual throttle bodies. The S42 unfortunately did not share the same valvetrain as the M42, and is a solid lifter valvetrain (possibily from the S50Euro) fully capable of over 9000rpm, but was limited to a 8500rpm redline, as dictated by touring car rules. It was mounted upright in the bay, not slanted, and ran on a full dry sump oiling system. The pistons had a static compression ratio of around 12:1, and running on pump gas, the S42 made around 280hp (and up to around 310hp later in it's life)."
Jõunumbreid tegid need mootorid siis:
S42/95 FIA 2.0 L 300 hp - 255 Nm
S42/96 FIA 2.0 L 308 hp - 260 Nm
S42/97 FIA 2.0 L 315 hp - 260 Nm
* veel mõni aeg tagasi ei teadnud ma midagi sellisest mootorist. Herr Lill tegi sellest juttu ja siis otsisin netist tiba infot lisaks.
Alates 2006 on selline: http://www.totalmotorsport.com/Features ... .asp?ID=28
Postitatud: 18.04.2007 23:00 54
Postitas erik
Venelane võtab päris julgeid poognaid oma m3ga.
http://www.youtube.com/watch?v=TUv6csbt ... ed&search=
Postitatud: 19.04.2007 22:04 24
Postitas jockker26
Väike crash.
Postitatud: 20.04.2007 21:03 52
Postitas erik
Postitatud: 29.04.2007 19:56 31
Postitas Roland325
Minu üks lemmikuid viieseid :shock:
Postitatud: 29.04.2007 21:11 57
Postitas joh
Roland325 kirjutas:Minu üks lemmikuid viieseid :shock:
Oyea, see on väga hull aparaat!
Postitatud: 10.05.2007 03:15 34
Postitas AARE540
SIIN veel üks, vähe pikem video eelpoolmainitud norrakate M5st...
Postitatud: 14.05.2007 21:54 45
Postitas erik
Postitatud: 15.05.2007 16:05 13
Postitas silver
Postitatud: 01.07.2007 11:07 23
Postitas priitv8
M1 sound:
http://www.myvideo.de/watch/1812224
Registreerunud kasutajad saavad siit ka ilusaid pilte samalt ürituselt vaadata:
http://forum.e34.de/thread.php?threadid=84283
Postitatud: 04.07.2007 10:53 57
Postitas Elmut
http://youtube.com/results?search_query ... NG&search=
Head videod kohtumistest,muusika (Y)
Postitatud: 09.07.2007 12:25 55
Postitas Roland325
Postitatud: 10.07.2007 12:15 47
Postitas Elmut
Väga kurb:( :(
Postitatud: 10.07.2007 20:23 52
Postitas Roland325
Üks e30 325 jälle vähem :(
Postitatud: 11.07.2007 12:14 35
Postitas Henrik88
Lahe M3
Postitatud: 11.07.2007 15:56 26
Postitas Elmut
Liiga kenad;)
Postitatud: 14.07.2007 10:56 10
Postitas Cardo
Postitatud: 19.07.2007 19:30 02
Postitas Hannes
http://www.liveleak.com/view?i=9ca_1184789773
see mõjus bemmi mainele küll hästi :D
Postitatud: 29.07.2007 23:45 37
Postitas priitv8
Postitatud: 31.07.2007 06:45 13
Postitas KRANTS
miks paljudel bemmimeestel närvid liiga kiiresti üles ütlevad :?: :shock:
Vaadake mis juhtub :!:
alguses pildimaterjal- MIS JUHTUS, pärast lõpus video- KUIDAS JUHTUS :!: :mad:
Postitatud: 05.08.2007 00:39 30
Postitas priitv8
Candid Camera:
Postitatud: 07.08.2007 01:12 09
Postitas Roland325
Üpris "kihvt" kurv
Postitatud: 08.08.2007 18:21 35
Postitas darklight
:cool:
Postitatud: 19.08.2007 10:48 00
Postitas erik
Postitatud: 21.08.2007 18:27 09
Postitas Mardo
