Mure on selline, et oli soov navi kaarte uuendada, kuid ei saa navi dvd'd kätte. Viskab sellise pildi ette:
![Pilt](https://www.upload.ee/thumb/6256695/e70navi.jpg)
Netist leidsin ainukese kasuliku asjana sellise postituse:
Hetkel tundub probleemiks olema boldis olev tekst: "DVD lock always active: the eject button is disabled". Siit nüüd küsimus, et kuidas selle luku eemaldada saab - kas ainult esinduses või mõni kaabliga tegelane saaks sellega ka hakkama?Couple minutes with WDS helped. The rest is copy-paste from WDS (Only default pin hided):
Navigation system: DVD lock
The optional extra ?anti-theft protection navigation DVD? enables a DVD lock of the navigation DVD for corporate customers. The corporate customer vehicles are delivered ex works with this optional extra. Vehicles can also be upgraded by means of the Progman and then adjusted with this service function.
New vehicles are delivered with the following default settings:
DVD lock always active: the eject button is disabled.
Up to model year 03/2006, vehicles were delivered with the following default settings:
DVD lock with PIN query active.
The default 4-digit PIN is XXXX.
The 4-digit PIN is queried when the eject button is operated. When the PIN is entered, the navigation DVD is ejected.
This service function can be used to read out or change the settings of the DVD lock.
Activating or deactivating the DVD lock
The DVD lock has the three possible states described below:
DVD lock inactive: the navigation DVD is ejected when the eject button is operated.
DVD lock with PIN query active: the set 4-digit PIN is queried when the eject button is operated. When the PIN is entered, the navigation DVD is ejected.
This service function can be used to change the 4-digit PIN.
