Sooviks abi oma E46 elektriliselt kokkuklapitavate peeglite probleemile. Ostsin auto ja ykshetk peegleid kokku klappides keeras kõrvalistuja poolne peegel imelikku asendisse. Tegi pöörates häält nagu oleks millesdgi yle käinud ja jäi antud asendissse seisma.Tagasi pöörata lastes jääb normaal asendisse. Tagurdades liigub peegel alla, nagu ta peagsgi tegema. Abi väga teretulnud!! Ette tänades!!
Peegli sees on mikrolüliti (alt vist sai isegi ligi, seal kork).
Kui see ei funka, siis paneb peegel segast.
Teiseks kui laagrid on rooste minemas, hakkab ka segast panema.
Teen kodudes elektriasju korda. 36€/h. Anna murest märku.www.motovool.ee
Tundub kuidagi metsa jooksmisena see ettepanek ... aga sinna ei taha minna! Sooviks ikkagi asja korda saada. Auto korralik, see oleks ainuke probleem mis vajax lahendamist!
Viimati muutis andresuk, 21.01.2015 20:59 15, muudetud 1 kord kokku.
Kuno_T kirjutas:Arnis, palun lõpeta juba peeglite mikrolülitite jutt, neid ei ole mitte ühelgi seal! Ka teistel mudelitel!
Folding In Mirrors
The electric motor drive is used to fold in the outside mirrors (special option) in the opposite direction of driving.
The button to fold in the mirrors is located in the switch block on the driver's door. The button signal is routed via the P-bus to the peripheral modules in the doors. Depending on the position of the mirrors, they are then folded in or out accordingly.
In addition to the external design differences, the mirrors for the production vehicles model E38/E39 from the mirrors for the model E39 M5 (motorsports design).
A microswitch is integrated in the mirrors the production vehicles that switches a ground signal to the relevant peripheral module when a mirror is folded in or out by hand or by impact. The microswitch is necessary as folding the mirror in or out uncouples the mirror mechanism from the fold-in motor. If a mirror which has been mechanically uncoupled is activated by the button being pressed, the fold-in motor will move the mirror in the fold-in direction until the microswitch registers the mirror being engaged. The maximum activation time of the motor is 15 seconds.
Thanks to a modified mirror mechanism, this microswitch is no longer necessary for the mirror of the E39 M5.
Since the mirror fold-in motors block when operated, thermal overloading is possible if operated frequently. In order to avoid overloading, a repeat lockout is provided which blocks the fold-in motors for 3 minutes after 6 operating attempts within 1 minute.
Viimati muutis arnis, 07.01.2015 00:16 31, muudetud 1 kord kokku.
Kysimus kerkis veel yles , kas neid ymber saab progeda et nad automaatselt kokku ennast klapiksid kui super marketite parklas autos välja tulla? Tohmakad taovad neid ära!
