L: E30 Service & Õli tulede nullimine
Tean et on olemas lõhike topic asjast kuid ripputaks uue täiustatud variandi ülesse.
Kui keegi saab mahti tõlkida oleks tänulik!
You'll need a piece of electrical wire (10/15 cm) to serve as a jumper wire.
According to Patrick Farrel, a BMW master tech working at a dealer in MD, you should always use a fused jumper wire.
First, locate de diagnostic socket, at the engine compartment. There are two different types: up to 1987, it's located near the intake manifold, and has a red cap:
After 1987, you have to find a big round black plastic socket, with a cap held by a plastic strap, located near the oil dipstick (M20 engines) or near the firewall, driver's side (M40 engines):
Pull the cap (early connector), or unscrew it (late connector), and you'll see a number of connectors, depending of the type of plug (see the diagrams below).
Varajasem Service Pistik
Hilisem Service Pistik
According to the type of plug on your car, locate the right connectors, marked red in the diagrams;
Use the jumper wire to connect them together;
Turn the key to ON position, without starting the car;
When the 5 LED's in the dash light up (3/4 seconds), turn off the key. If you keep the ignition on, another 6/7 seconds, after the LED's appear, you'll perform an inspection reset, too.
Disconnect the jumper wire.
Make sure you jump the right connectors! The best way to follow the diagram for the late type connector is to match its center circle cut (that looks like a pacman )) with the one in your car. The earlier one has a flat side, so it's easier to follow.
If you can't reset the lights, or if they reset and return after a few days, you probably have to replace the SI board batteries. Check the articles about this subject at the previous page.
Re: L: E30Service Light Reset vs Service & Õli tulede nu
jJanno
Just täna seda tööd teinuna julgen öelda, et see joonis pole just päris täpne. Minu autol (M40@1994) oli see keeratud 180 kraadi. Google otsinguga leidsin ma just täpselt sama allika ;)NoComment kirjutas:
jJanno
exTouring
Tõsi ta on aga arvan et se ei oma tähtsust...jjanno kirjutas:TereJust täna seda tööd teinuna...NoComment kirjutas: Hilisem Service Pistik
Kuna antud joonisel onvanemal tüübil on märkitud pistiku välimised siinid...
Uuemal taas on keskel PAC-Man kuju mis paneb suuna paikka.
( Antud joonisel vasakul kaks ja paremal 1 )
Ise tegin täna asja ära ja asi töötas...
Kus juures endalgi oli asi teistpidi ja mitte 180 vaid 90 kraadi...
Antud õppetuses on ka PAC-Man teema kirjas!
Kontaktid on pesas nummerdatud, eksimise vältimiseks oleks kena ka need nr anda, mis kokku ühendada.
Resettimise jutt on vale. 3...4 sekundi pärast nullid ära "kella/inspectioni". 6...7 sekundi pärast rohelised indikaatorid. Testitud, kindel, et niipidi töötab. Teisiti pole ju loogiline, sest "kell" (Jahreskontrolle) käib aja järgi sõltumata rohelistest. Ma ei taha ju õlivälba indikaatorit nulli lasta, kui mingi "kell" poole välba peal koos Inspectioniga lööb.
Sõidurõõm
Uuel pesal on numbrid kontaktide juures
Kindla peale on see BMW Service info Annavad raha teenimise allika ära
Sõidurõõm
kõigis pesades on alati klemmide numbrid.NoComment kirjutas:Svenp kirjutas:Kontaktid on pesas...
1. Minu pesas ei olnud mingeid numbreid... Milleks ma muidu jooniseid oleks otsind.
2. 3-4 Sec töötasid minu jaoks ideaalselt...
3. Antud info pärineb BMW Servicest... Ei taha nagu vaielda teemal kas töötab või mitte...
