1992 E36 puldi õpetamine.
Cert85
Postitus Postitas Cert85 »
Tere!
Olen probleemi ees, kus ei saa autot puldi õpetamise reziimi.
Olen proovinud :
Instructions
Instruction Set One
1
Make sure that all the doors, trunk and hood are closed.
2
Open the trunk door. Open and close the driver’s door.
Sponsored Links
Free Programming Courses
Get started in minutes! Become a Software Engineer
code.he.net
3
Put the key in the ignition cylinder and turn it on and off five times. Don’t actually start the engine. The alarm should chirp a confirmation.
4
5
Press any button on the remote to program it. The alarm light will flash to acknowledge a successful programming.
6
Repeat steps 4 and 5 for any other remotes.
7
Exit the programming mode by leaving the driver’s door open while closing the trunk door. Then close the driver’s door. You should hear the alarm sound off to confirm that you’ve left the programming mode.
Instruction Set Two
8
9
Insert the key into the ignition and switch it to position 1. Turn it back again. Repeat this four more times. Then remove the key from the ignition cylinder.
10
Press the “Lock” button three times while holding down the “Unlock” button. Then release the “Unlock” button. The door locks will then cycle to confirm that you did it correctly.
11
Repeat step 3 for each fob that you need to program.
12
Exit the programming mode by inserting the key into the ignition and turning it to position 1 and then taking it out.
Ja väikse muudatusega siin:
PREPARATION
1.Cloce all doors, trunk, and hood
2.The security system must be in 'disarm' mode. The key must be removed from the ignition key slot.
ENTER CODE LEARNING MODE
3.Open trunk and leave it opened.
4.Open the drivers door and sit in the drivers seat.
5.Close the drivers door.
6.Cycle the ignition switch 5 times between the 'OFF' position and postion 2,(ignition 'ON', all dash warning lamps will illuminate). The red status LED will illuminate continuosly, and the siren will 'chirp' once, to indicate that the code-learning mode has been initiated.
Do No start the engine
The Ignition switch cycling in step #6 must be performed within 10 seconds.
The sequence in steps #1-#6 must be performed within 45 seconds.
REGISTER/DELETE ID CODE(S)
7.Open drivers door, (remain seated in the drivers seat)
8.Close the drivers door.
9.Press and release any button on the remote you wish to register in the system. The status LED will shut off momentarliy to indicate that one code has been registered.
10.Repeat steps 7 thru 9 to register the three ID codes.
---It is possible for the system to memorize a total of 4 different ID codes. As a new code is initialized into the memory, the oldest code is automatically deleted. If you had lost your remotes and wished to delete the lost remote ID codes from the memory, you could initialize the ID codes from a newly purchased replacement transmitterfour times thereby deleting the previous ID codes fromt he system memory.
EXITING CODE-LEARNING MODE:
11.Open drivers door, and exit from the vehicle, leaving the door opened.
12.Close trunk.
13.Close drivers door. The LED will turn off and the siren will 'chirp twice.
14.The initialization procedure is now completed; Test all remotes to confirm operation.
Ei saa mina seda pasuna "piiksu" kätte ega tulukest käigukangi juures põlema.
Alarm ise töökorras ja tuli vilgub, kui uksed võtmega lukustada. Samuti töötab ka pagasiruumi lüliti, sest auto läheb häiresse, kui luuk "avada" alarmi all olles.
Minu mõistus on otsas.
Ehk on kellelgi head nõu anda? :)
Cert85
Re: 1992 E36 puldi õpetamine.
Sain ka postkasti ühe kirja, aga ka see ei aidanud mind. :(
Pole kellelgi ideid rohkem või õpetussõnu lausuda? :)
MargusA
Klubiliige - moderaator
Peamine sõiduk: e61
Postitus Postitas MargusA »
Mul oli ka nii et pult ei töötand.Neid puldi õpetamis viise on mitmeid.Proovisin erinevaid ja siis kogemata hakkad kesklukk tööle.Otsinguga peaksid ka leidma.
Minul oli signa pasun rikkis.Ostsin uue ja ühendasin ära.Aga probleem on nüüd selles et olenemata kas auto on või ei ole valve all hakkab pasun häält tegema :roll: mis teha?
